Blower Motor Fuse Blowing
Please help with any ideas you may have! I hae a 2003 X-Type and about 2 weeks ago fuse 99 blew while my wife was driving home from work. I found the blown fuse and replaced it. I started the car and went through all of the controls and it worked fine. The next morning i started her car for her before leaving for work. Ten minutes later when she got in, it had blown again and was not working. So yesterday I went to change the fuse again and this time it blew as soon as I inserted into the slot. Any ideas on where to start and what you think might be wrong with it?
Thanks,
Matt
Thanks,
Matt
Not a good one, obviously you have a ground short, check the wires under the dash, something has rubbed or heated or melted. Good luck, it will be a job tracing it. Try finding the wire where it plugs into the blower, unplug it and replace the fuse, look for the cooked connector then work your way back.
Received 2,190 Likes
Received 3,887 Likes
Ok, after further investigation the fuse that is blowing is fuse #99. Based on the fuse panel information it control the luggage compartment light, footwell light, puddle light, vanity mirror light, interior light, roof console unit and the air con control unit.
As I mentioned, now as soon as I insert a fuse it blows so it must be a ground short somewhere. Any suggestions on where to start in diagnosing where it might be?
Matt
Matt
The following 2 users liked this post by Brutal:
Rollerman1953 (12-13-2011),
Sam1 (08-17-2012)
many thanks Brutal,
your advice was spot on. I had my X type in the shop trying to trace a dead short on fuse 99. They spent a couple of hours and failed to find the fault, 15 minutes after reading your advice I traced the fault to the sunvisor. One of the screws had gone through the wires. Many thanks, you have saved me hundreds of $$$$$$.
Great to know there are people like yourself who are willing to share your information.
![Icon Worthy](https://www.jaguarforums.com/forum/images/smilies/icon_worthy.gif)
Rugbybooster (02-28-2013)
you guys are welcome and this is the kind of experinace you find from many dealer tech that have worked on your type cars for years. As I tell frineds all the time. TAKE YOUR CAR TO SOMEONE THAT KNOWS AND WORKS ON YOUR TYPE CAR EVERYDAY. No matter Jag, GM, FORD, BMW etc... Many times alittle more upfront for experiance and expertise saves alot more down the road
