bolt pattern
Received 3,922 Likes
myjag, the rim will bolt up just fine more than likely, but the other thing to keep in mind is whether the 5x4.25 bolt pattern is a hub centric design. I think you will find out that it is not. In this case, that would be a bad idea to mount those rims to our cars. In the hub centric setup, the wheel studs are only responsible for holding the wheel against the hub and taking side load. In other rim styles, the complete weight of the car is set on the wheel studs. Therefore, those wheel studs need to be much stronger.
baskervillema
10-01-2015 06:43 PM
