Brake Booster Replacement - Tips?
Hello All -
I recently identified that the two lean codes I was getting is due to a vacuum leak in the brake booster.
I've ordered an OEM Bosch booster and plan to replace it this weekend.
Any tips from anyone that's done this before? Do the brake lines have to be removed from the master cylinder?
Seems pretty straight forward, get coolant tank out of the way and then have at it....but wanted to check.
Thanks!
Thanks!
Hello All -
Thanks!
Thanks!
