Brake caliper
Received 9,013 Likes
I was in process of changing my rotors and the piston won't turn back in the caliper 05 xtype vdp rear driver
Here we go with that perennial problem again.... about which is Left Hand and which is Right Hand. (US/UK think differently)
Much better to leave that bit out - I reckon. (rather than to confuse matters)
The pistons can only retract if they are engaged on the internal pin... so try one way then the other. (with mentioned pressure) You will soon observe which is correct.
Received 2,266 Likes
Thanks for your comment about Left and Right hand.
It would be most appreciated (by all) if you could explain or name the
source of this generic information ? for without that - your statement is
merely another comment. (and most here express theirs -eh)
Aking: If you'd like, I can meet you in west or north Houston to persuade the piston to retract.
Per the above posts:
+ Apply pressure to the piston while you spin it, using:
........(1) a C-clamp and brake piston cube like this: Brake Piston Cube OTC4589
........(2) A brake caliber tool like this, which most auto parts stores let you borrow for free: OEM/Disc brake caliper tool set
+ Rotate the piston counter-clockwise for the US driver-side caliber. Rotate clockwise for the US passenger-side caliber
+ You already relieved hydraulic pressure behind the piston
+ Put a little silicone grease under the rubber boot encircling the piston so it won't tear as the piston turns
Lcgi (09-22-2014)
Easiest thing to remember:
They are turned so that the top is moved towards the front of the car.
That means that right Side / Near Side / UK or Strine Driver's side is clockwise,
left Side/ Off Side/ UK or OZ passenger is counter or anti-clockwise.
Just always towards the front.
The problem that often arises here especially if both rear Calipers are off and away from the vehicle (as likely the case when doing a full O-ring / dust boot replacement service) is keeping track of the Left and Right units.
Jaguar uses the 'from the rear looking forward' convention to illustrate diagrams for engine cylinder numbering.
Lcgi (09-22-2014)
The convention has been used throughout the automotive, marine (albeit port/starboard) and aviation industries long before any of us were born. Always the captain/pilot/driver looking forward in the normal direction of travel.
Thanks for your elaboration.... about origin of past conventions and Jaguar's apparent adoption of same.
Funny how you relate this to in-line mounted engines (4.2 S-type) to the actual
topic of cross mounted engines of the X-Type.
Does anyone know if the convention adopted by Jaguar for the X-Type is specified in any Jaguar X-Type documentation - for that would indeed be the definitive and conclusive reference !!
The answer you seek is in JTIS.
