Brake caliper no fluid
i get fluid out the bleeder on the right side which was still good, but the left side which i replaced wont get any fluid from the bleeder the line gets fluid but the bleeder will not nor will the piston engage i triple checked my install dont know what it could be
Received 3,932 Likes
akingcrook, it could be that the copper washer that provides the seal is blocking the flow of fluid. That or the small port in the retaining bolt is plugged and that needs to be cleaned out. If you are getting fluid into the caliper, then it will come out the bleed port as it is basically a big void inside the caliper between the brake line and the bleed port.
wvanepps
10-04-2015 10:01 AM
Richard_gib
09-12-2015 07:08 PM
