Brake Calipers and Rotors
I want to upgrade my calipers but I am confused on how these things are sold...
From most of the websites I landed on via google it seems like they only sell "front, driver" and "front, passanger" There is no "rear, driver" or "rear passanger"...
How are brake calipers sold?
I know, dumb question, but I'm confused! Isn't there a way to buy the whole set?
I am planning on a wheel/tire upgrade soon and want to change my rotors to these EBC ones, http://ebcbrakes.com/automotive/spor...rs/index.shtml , and I was thinking of changing my calipers to match my whole set up I'm planning.....
Any suggestions?
Any suggestions?
How are brake calipers sold? I know, dumb question, but I'm confused! Isn't there a way to buy the whole set? I am planning on a wheel/tire upgrade soon and want to change my rotors to these EBC ones, http://ebcbrakes.com/automotive/spor...rs/index.shtml , and I was thinking of changing my calipers to match my whole set up I'm planning.....
Any suggestions?
Any suggestions?
As for those EBC Rotors... Any feedback on those? Will my stock calipers have a problem with those rotors? or if I get a set of 19" rims is it going to effect anything?
Thanks again.
Just spoke to a shop out in California and he quoted me some prices for a full rotor and brake pad set.
I was told that if you replace your rotors you shouldn't use a worn brake pad due to the fact the brake pad has already "bed down" on the previous rotors... True or a bunch of bs?
Anyways, I got quoted for a full set of redstuff brakes for $154, and a full set of those rotors I linked for above for $258... Coming to a total of $412.00 at the door for a full rotor and brake pad replacement. I'm waiting for a local shop to try to get me something cheaper...
Sometimes a CC with 0% APR for one year gets you creative in projects lol.
Received 3,887 Likes
620, yes, when putting on new rotors, using new pads is a requirement. Essentially if there was any grooves put into the old pads, the high points of the pads will be the only ones touching with the new rotors. So, you would effectively have reduced your braking ability atleast for the short term. Not to mention because you are only making contact with part of the pad, you are now cutting those same grooves into the new rotors vice leaving them nice and flat. If you just bought pads and they are still flat (test by putting a flat edge across the rubbing surface and then see if you can see any light between the flat edge and the pad, no light means ok to use). Even then, pads aren't that expensive and to have the garantee that you are not going to mess up anything is always nice to have.
Received 9,007 Likes
Ceramic pads are best for reduced dusting, but the initial bite isn't as good. I've had ceramics that dusted 1/2 or 1/3 (measured by wash intervals) compared to even rear wheels with semi-metallic. Meaning since the ceramics were only up front, if I had 3 weeks of sunny weather, the fronts required no washing for all three weeks, rears would need a touch each week (car would need dusting). With stock setup, I need to touch fronts twice per week, rain or shine.
Supposedly the YellowStuff are not supposed to take any warm up time like most high performance pads require before optimum braking. Not sure if I buy that or not, haven't tried them myself.
Just about anything is better for less dust than OEM's. My Centric ceramics don't dust much at all, never get the black soot buildup even if I'm lazy for a few weeks.
wvanepps
10-04-2015 10:01 AM
