Brake lights
Old 06-20-2012 | 09:04 PM
Alex33t's Avatar
Default Brake lights
Hi I just join and a a problem with my brake lights being out.I have an 03 X Type and I have checked the fuses and the bulb.They are all good but my brake lights wont come on.The center brake light in the rear window does come on .Someone please help..........
Old 06-20-2012 | 09:56 PM
Thermo's Avatar
Alex, looking at the diagram for your car, if the 3rd brake light is coming on, then you have power to the brakes. Your problem lies with either the wrong bulb installed in the tail lights or the bulb is not properly installed. You can verify that you have power back there by taking a multimeter and measuring between the green/red wire (driver's side) and chassis (or you can use the black ground wire) or the orange wire (connected to Pin 5, not the one connected to Pin 3) and chassis (passenger side). If you have 12 VDC, then you have bad bulbs. Since you do not mention any problems with the other bulbs, you know the ground wire is good. So, that only leaves but 2 issues (bulb or wiring). If you have 12 VDC at the 2 wires I mentioned, then that pretty much proves it is the bulb. To confirm this, if you pull the bulb out, look on the metal part of the bulb. You should see a number stamped on it. Is the number 7528? If not, then odds are you have the wrong bulb. Just because the base looks similar, does not mean it will work. There's more kinds of bulbs out there than I care to admit to.
On a side note, are you trying to get some LED bulbs to work? That can open up another can of problems.
Let me know, we can get you through it.
Alex33t (06-21-2012)
Old 06-21-2012 | 08:18 AM
Alex33t's Avatar
I haven't changed these bulbs and not going to LEDs.
It just seem odd that both sides would go out at the same time.
I will do the check that you suggested
H20boy
07-23-2021 10:39 PM
mbergen
10-23-2019 11:26 PM
PMKimpton
08-03-2019 09:22 PM
KarimPA
09-12-2015 09:15 AM
motorhead69
09-09-2015 11:04 AM
Quick Reply: Brake lights
