brake locking
Received 3,932 Likes
Sounds like a problem with the ABS unit. You have replaced the other common components and since it is affecting all 4 wheels, that narrows down what the possible source of the problem is. If you do some looking here on the site, others have had the same issue and you can get a few checks that you can make to help confirm what I am saying.
Did you or anyone do brake work recently (pads, bleeding, etc.)? If so read this ENTIRE thread for a possible cause, reason and fix =
https://www.jaguarforums.com/forum/x...-208617/page2/
If not that then as Thermo said, probably ABS module.
very easy! your brake booster is the problem ,when you changed the master cylinder theirs a rod in the booster it has 7mm nut on the end
get a friend to push the pedal all the way down
2 = get a needle nose and grab the stem the turn the 7mm nut on the end 3 -4 times in bolt it back together and your done
doooooo not buy a new booster just adjust the one you have the way i told you
Forrest Keith
11-20-2022 05:06 PM
MikeofBonsall
12-02-2018 03:56 AM
