Brake Pressure Sensor Question
Received 3,923 Likes
flyrr100, yes, you will get a little trickle of fluid to come out. What you are going to get is gravity flow coming from the brake fluid reservoir to the ABS module. Are you going to get a solid stream, by no means. But, you will have some fluid leaking out. Imagine like you just barely cracked the faucet on your sink worse case.
What I would tell you is to have the new sensor handy so you can pull the one sensor out and then immediately thread the new sensor in.
KarimPA
09-12-2015 08:15 AM
