Brake problems???
![Unhappy](https://www.jaguarforums.com/forum/images/icons/icon9.gif)
Hi everyone, am new here just bought a 2002 Jaguar x-type and love it
So I have this problem I replaced front rotors and all break pads because I was having a hard time braking. The problem would go away when the abs light would come on though. The rotor that had the most damaged was front drivers side, short story I replaced rotors and pads and still have the same problem, could my caliper be bad or what could it be please help.
When you did the brakes on the front did you have any problem pusing pistons back into caliper? Did the pads and rotors look as they had been heated pretty extensive? This is an 11 yr. old car, you did not say how many miles? Have the rubber hydralic lines been changed in the last 5 yrs.? So, problem lies between deteriated hoses or overheated and sticking calipers, if no ABS codes! Hard to pinpoint without actually seeing the system.
You can change the whole braking system and still have ABS codes. I changed to drilled rotors and carbon pads. Replaced the fluid and still had ABS problems. Look first at taking off the wheel speed sensors and giving them a good clean. That may be it. If not you are starting to look at paying for parts.
But get the codes and you should get your answers.
