Brakes
Hi Just brought a Jaguar 2.2 X Type 2008 it stops OK but I am used to lighter cars that stop quicker whats the best way to improve the breaking . ie what are the best type of Pads , and just a gusse can you up rate with braded hose ( I have done this before on motorbikes ).
I am new to this forum there may have been a post on this subject before I do
appoligize in advance if there has been. I would apprieciate your views you may have tried diffrent things .
Check for better prices
Jaguar X Type (Mondeo Chassis) From Years: All years Goodridge 'PHANTOM' STAINLESS STEEL BRAKE LINE KITS (Stainless Steel Fittings) 4 Line Kit
For the pads EBC redstuff or yellowstuff are options
EBC Brakes | EBC Brake Pads | EBC Brake Discs
Received 3,909 Likes
Paul, I have upped the brake performance on my car. I did it with 2 things. I am first running 235/40R17 wheels (1 step up from the factory wheels that came with the car). So, I have an extra 10mm of tread width making contact with the road.
The other thing I did was I got on e-bay and bought a cross drilled/slotted rotor kit through BrakeMotive. The kit cost me $180 USD for all 4 rotors and ceramic pads all the way around. Install is easy. If you can change brake pads, you can install this.
Upgrading to the stainless lines probably wouldn't hurt either. Probably stiffen things up a bit to just add to what you are after.
As for stopping ability, I now clear off the seats if I stomp on the brakes. I actually worry about planting the front bumper into the road surface. Some of the best money that I have spent on the car.
xjrjag
09-24-2015 10:08 PM
