broken fuel door-
Hello,
There are a few other posts on the subject so do a search and you should find them. As I recall, it's a bit of a job since the inner fender shroud has to come off, etc.
The arm that connects to the filler door on my car cracked and I carefully glued it with SuperGlue to hold it in position and then followed-up with a two-part, five minute epoxy specifically for plastics made by Duro. Any hardware store will carry it. If you do it carefully, you can repair so it won't be noticeable. Be sure to mask the area around it with tape to protect it from glue.
Good luck,
Steve
Good luck,
Steve
Hello,
Here's one of the posts. After I saw that mine was cracked I read the steps and decided to glue it. Maybe you can, too. It's held up fine for a few years...
https://www.jaguarforums.com/forum/s...ight=fuel+door
Good luck,
Steve
Good luck,
Steve
markrkolb (12-05-2010)
deanh
09-06-2015 08:20 PM
