Bulb Replacement!
Old 01-29-2010, 07:40 AM
zyggo's Avatar
Originally Posted by muddyjag
the slam panel is the panel the bonnet closes on ,the flat panel above the headlights,there is a small hole in it that you can poke a long screw driver through and just reach the clip
Yes sir I saw that. But how to you pull the clip back on after you replace the bulb?
Anyhow, does anyone think there's enough room in there to change the bulb? On the driver's side I had to loosen and relocate the fuse box. Now on the passenger side The ABS unit is like 3cm behind the bulb cover!
I got the clips loosened. Like I say above, I have no idea yet how I'm going to get the outboard clip back on... I just can't seem to get the cover to come out of there.
One does do these bulbs from inside, rather than taking the front lens off right?
Thanks very much for your replies.
Old 01-29-2010, 08:47 AM
muddyjag's Avatar
the clip is easyly put back on with a long screw driver , i had no problems replacing the bulbs , the cover can stay in gap there is enough room to replace bulb
Old 01-30-2010, 06:35 PM
zyggo's Avatar
Cool. I didnt think there was room. It's bloody cold around here so I didn't spend too much time on it! Thanks!!!
Old 01-30-2010, 08:30 PM
queenmb's Avatar
Red face
If all else fails, get someone with small hands to reach it. I never have a problem removing mine. It takes about 5 minutes and never had to loosen or relocate anything.
Old 01-31-2010, 10:52 PM
zyggo's Avatar
Oh if I had such help!
Thanks for the advice all.
Old 09-27-2011, 04:32 PM
bulkmail07's Avatar
I did not see the answer to my question here or just did not recognize it. 2004 X-Type. Is there a trick beyond brute force to removing the H1 bulb from its socket? I am afraid of breaking the socket if I attempt to pry the bulb out. Really appreciate any suggestions. Thanks all
John/2004 X-Type (wife's car)
Old 09-27-2011, 09:42 PM
Green Machine's Avatar
Smile
I just replaced bulbs in my front fog light. They were the original bulb and were really stuck in the sockets. I just used a small screw driver and worked the old bulbs back and forth until I was finally able to pull them pull them free. I would imagine this method will work for all of the H1's.
  #28
Old 08-30-2016, 06:20 PM
Harry Peter Rose's Avatar
same problem but cannot get the bulb out!
screw or out pull out? .........could it be fried??
what and from where did you get a replacement?
99xk8guy
06-05-2023 06:28 AM
RoyLittle0
05-25-2023 02:38 AM
Forcedair1
05-14-2023 03:28 PM
afterburner1
12-16-2015 12:12 AM
KarimPA
09-03-2015 07:32 PM
Quick Reply: Bulb Replacement!
