A/C Compressor Issues
My Jaguar service tech said my compressor has a slight leak (2007 - 96K miles); rather than change it out now I am trying A/C Pro recharge/sealant. Too soon to tell if it will buy me more time, but seems to have made a big difference so far. (BTW, I live in Florida so I'm in a perfect proving ground for this!) Good luck.
To add my $0.02 here - the first pic looks like the leak is from where the two halves of the compressor are bolted together or from the clutch seal - in either case - the compressor should be replaced as at this point - with that kind of leak - the compressor oil is more than likely gone and the internals will just chew themselves apart.
In the second pic - if this was the only leak you had - you could change the O-Ring seal - only $11 - but again, you have a major leak as I stated above.
Finally, those seal kits would not work in a situation like yours and I for one wouldn't trust letting that stuff into the AC system - more trouble than what it's worth.
Received 2,193 Likes
abonano, Brutal, AlfaVeloce, and Pacobell - thank you all very much for your responses. Looks like I'll be needing to replace this soon.
I noticed the issue when I was underneath the car to see what it would take to perform the Compressor Valve Spring Modification, since my A/C isn't cold while stopped. Have any of you replaced your own compressor? Is it worth trying to do myself?
ccash
ccash
you can get a flush system you put to a 150 psi compressor for 50 bucks at granger. Guages at Harbor freight for 50 bucks. A vacuum pump is several hundred. Got all the parts at discount ac dot com for about 300 bucks. The compressor comes out easy if you have ramps to drive up on. You'll have to make some extensions for the ramps to clear the body. The orifice tube isn't too bad if you cut a wrench in half so you can turn it off and clear obstructions. Take the wheel well liner before you drive up the ramps as you need to turn the tires away from screws to get them off. The accumulator comes off easy. My tranny pan has a slight leak. I need to replace the gasket, looks easy if the battary comes out. I found a stripped tranny pan bolt. I never used a heli coil on aluminium, is there a special kind?
Received 6,330 Likes
