A/C. high pressure kicks in
Fitted new comp, drier, orange orifice and condenser. evac and recharged to correct amount. and 7.56 oz oil. pag 46
performed the above twice but still have same fault. ( two diff kits)
If car sits out in the heat of the day. the high side goes above 400 and kicks out on high side. it will do this with rpm above 1800. and will cut in and out on high side in cruise at 70. after about six miles it settles down a bit but pressure still high and felt on motor loading.
temp here in AZ is 113.
Once ambient temp goes down to about 87 all works good.
Feels like condensing issue.
Fans are at 95% pwm
Question.. are both fans controlled at the same speed and do the fans turn off above 50 / 60 mph +
Cant find fault.
Any Ideas
Pete
35 year tech. all ase inc L1
Fans are at 95% pwm
Cant find fault.
Any Ideas
Pete
FS[SouthWest]: Red 2001 XK8 Convertible in Colorado
picard
10-12-2015 11:56 AM
