A/C Low Side Valve Location
Received 3,912 Likes
Looking at the JTIS, it says the low and high side ports are next to each other in the right rear corner of the engine compartment. You can tell the difference between the two in that the high pressure side will run between the condensor (located in front of the radiator) and the dash where the low pressure port is going to be between the dash and the receiver (small metal bulb in the return line, which then leads to the compressor).
Hope this helps.
Hope this helps.
Wolfy
05-28-2024 08:06 AM
KarimPA
09-12-2015 08:15 AM
