A/C Pressures way off
Hello Gentlemen,
The A/C in my '02 has sort of intermittently gone bad (warmer and warmer...But sometimes nice and cold!). I checked the low and high side pressures with a good gauge and here is what I got:
HP: 120psi
LP: 100-102psi
(both readings with system at high, closed to any other attachments, and with the compressor clutch engaged).
I know this is probably a bad compressor, but in an attempt to NOT change the compressor I am asking for any other possible explanation. I have looked all over the forum and found something about the expansion valve and/or an "A/C compressor valve spring" problem. Do either of these things make sense with my symptoms, if so, can I replace them?
HP: 120psi
LP: 100-102psi
