A/C temp readings
The following 2 users liked this post by motorcarman:
Don B (07-02-2024),
Mr rx-7 tt (07-03-2024)
Received 12,953 Likes
Hi Mr rx-7 tt,
Are you unhappy with your A/C performance? In general, a mobile air conditioning system is considered to be performing properly and well when the dash vent air temperature is 40 degrees Fahrenheit lower than the ambient air temperature with the vehicle stationary and engine at idle. At extremely hot ambient temps, we don't expect a 40-degree differential, but something less, like your 37-degree differential.
You get lower vent temperatures while cruising at interstate speeds due to the increased air flow through the condenser and resulting improved heat transfer.
You might be able to improve your temps at idle by cleaning the space between the condenser and radiator and confirming that your electric fan is operating properly, but 58 deg. F in the ambient temps and humidity you describe is pretty good performance.
Cheers,
Don
Cheers,
Don
The following 2 users liked this post by Spikepaga:
Don B (07-03-2024),
Hi Mr rx-7 tt,
Cheers,
Don
Cheers,
Don
In my E55 the other day it was a 103 degrees and the car was blowing 30 degree air driving down the interstate.
Cookie_M0nster
06-07-2013 02:17 PM
