Camshaft position sensor 2003 x type 2.5
Bank 1 is the side nearest the firewall. The two cam shaft sensors are fitted, one to the end of each inlet valve camshaft, above the main drive belt. Not to be confused with the two Variable Camshaft Timing Oil Control Solenoids on the top surface of each of the cam boxes at the same end of the engine.
sabuilders
09-07-2016 05:43 PM
