camshaft postion sensor location
Received 3,892 Likes
2004xtype, the camshaft sensors are on the "backside" of the engine. I am not talking about against the firewall, what is meant by this is where the engine meets the tranny. So, in the case of our cars, if you stand by the driver's front wheel and look at the engine, you are looking at the back side of the engine. If you look on the side of the heads facing you, you should see a sensor there. In your case, the sensor is tucked under the intake. SO, odds are, you will need to remove the intake to get a good look at things.
Circuit A is the side against the firewall. So, you will have to most likely lift the intake manifold off of the car to access the sensor. Might be able to see it with a flash light before you just start ripping into things.
A is normally associated with cylinders 1, 3, and 5. B is with 2, 4, and 6.
Guy-Pierre Boucher
09-16-2015 05:55 PM
KarimPA
09-12-2015 08:15 AM
KarimPA
09-03-2015 07:32 PM
