Camshaft water pump drive adapter question
Geeze. Sometimes you guys make it so difficult and I end up having to figure out how to do something.
I had some time to look at how the water pump adapter is fitted onto the camshaft.
1. There is a very small gap between the end of the adapter and the last cam lobe. (1-2mm)
(Weeks ago, I had tried to hammer with some chissels and thinner metal wedges to try to make the gap wider and the adapter move, no luck)
2. This evening, I went through all my bearing splitters and found the smallest one I had. (About a 60mm X 60mm spliter)
3. The round 1/2 side edges barely fit into the 1-2mm gap.
4. I placed the camshaft horizontal on my press and carefully placed the splitter halves around the camshaft to adapter gap.
5 Loaded up press and was able to get the gap to widen to about 5 mm.
8 Bolted the bearing splitter together around the gap, put the camshaft vertically into the press, dropped a bolt that fit down the hole in the adapter and via the bolt, pushed the camshaft down off of the adapter.
Not as bad as I thought it would be.
