Can I extend the Heated Seat cycle?
Received 3,898 Likes
Darpie, unfortunately, the timing for the heated seats is set by the control module. So, unless you are good with electronics and feel like opening up the module and making your own modifications, looking like you are out of luck. You can't simply bypass the module and get power to the seat heat element as it is capable of heating up the seat to the point that it could become too hot. There is a temperature sensor in the seat that feeds back to the control module that controls the seat temp to either 42 Celsius on the high setting and 37 Celsius in the low setting. Either way the timer is set for 10 minutes. The 10 minutes will continue unless the seat button is pressed through the OFF setting or the engine is turned off. It will also turn off if it senses a problem. So, I would first try a timing of the circuit to see how long it runs. But, if you are getting something over 9 minutes, the timing portion of the circuit is good.
FS[LowerAtlantic]: 2007 S-Type $.2 For Sale
captbob73
10-24-2015 05:49 PM
Poet
10-06-2015 09:40 PM
adam699
09-12-2015 05:32 PM
jagent
09-12-2015 09:10 AM
