Can I get a quick summary for rear wheel bearings please.
Old 05-20-2015, 10:14 PM
innzane's Avatar
Default Can I get a quick summary for rear wheel bearings please.
Can you just pull it apart and slide in new bearings like a normal vehicle?
or
Do you really have to buy that big piece with the bearing and wheel stud flange?
Any other maintenance to do while that deep?
Old 05-21-2015, 02:35 PM
faltwen's Avatar
It's a complete hub.
Remove, wheel, brake caliper, disc and disc shield
Undo 4 x torx bolts, use puller to pull hub off driveshaft.
Bolt new hub on and replace all parts.
Easy (as long as the 4 torx bolts are not seized)
innzane (05-21-2015)
Old 05-21-2015, 08:01 PM
innzane's Avatar
OK, sounds almost the same with no greasy fingers.
My steering wheel puller may do the trick.
Thanks for the response.
Old 05-23-2015, 07:56 AM
Paulc732's Avatar
Best price I found was Rockauto.com
Timken ($125.79) is my recommendation but there are lower cost options.
PMKimpton
08-03-2019 08:22 PM
Harry Dredge
09-03-2015 03:04 AM
Harry Dredge
09-02-2015 02:26 PM
innzane
09-02-2015 10:08 AM
Quick Reply: Can I get a quick summary for rear wheel bearings please.
