can i get rid of the sat nav and use just aircon
Guest
Posts: n/a
Hi all, I have a 2003 x type 2.0d which has the 7" tutch screen sat nav-aircon unit in it, the sat nav-aircon is not working and is far to costly to fix (may as well scap the car for what the dvd unit in the boot costs) so I want to replace it with a standerd aircon switch panal, is it possable, can any one please help!!!!
You can switch it over to the standard automatic climate control system. You will need the climate control panel and the standard indash radio either cd or cassette. You will also need to get a bypass jumper for the D2B link at the nav module. You may have to have the radio programmed for your particular D2B setup ie. cd changer, phone etc. I would assume if you get a standard radio the setup should be correct but who knows.
Guest
Posts: n/a
Hi, my problem seems to be the dvd unit in the boot, the head unit flashes EXT 50 and 51, I have been told this is not an head unit problem but the dvd controle unit, I can get in to the diosnosic screen of the head unit and all looks well, so to answer your question I have only priced the dvd unit, around £400 for a s/h one, around £1400 for a new one if they can get one plus the price of the dvd disc.
I'm in the states so I'm not sure which side the parts will be located but a X-type with nav actually has a remote mounted climate control module that will have the exact same connectors the one piece climate control has. Here it is mounted on the passenger side just outside the center stack area. When you take out the nav unit you should be able to see both the module and related harness. The actual harness for the screen will just no longer be used. The radio you have now has all the connectors for the full size radio.
When upgrading to touch screen from climate you need a remote climate control module (RCCM) which is a different module to the non nav climate control unit (CCM) , so you would need a CCM to downgrade. I think it would also need to be programmed to your car at a dealer but not certain??
Not sure how much the CCM is but the RCCMis £428+VAT (15%) from UK dealers.
Guest
Posts: n/a
Yes yes yes got it sorted at last, turns out that EXT 50-51 message means the dvd unit in the boot is k***erd, after loads of serching i got one of ebay at a very good price ( half the price every one elce wanted) purdieboy163 is the man to look for great prices and service, Anyway got it pluged it in and wam it works!!!!
Thanks to everyone for there help, ho just one more thing can anyone help with where to get the latest firmwere update for the unit.
Finbarr1975
09-16-2023 02:52 PM
