can i use this tire size
Received 3,898 Likes
iownme, the size difference between the two is fairly insignificant. You should be fine with that size tire. Just keep in mind that your speedo will be off by 3.3%. So, when it is indicating 60MPH, you will actually be travelling 62 mph. Just something to keep in mind.
I am running 225/45R16's on my car right now. No issues with those.
They will rub.
I am assuming your Sport currently has 225/45/17 tires. The rolling radius is 199.27 cm.
The 205/50/17 that you are considering has a rolling radius of 206.50 cm. That is a difference of 7.23 cm or about 2.75 inches.
They are also narrower and will handle quite differently.
Gerard Radimaker
09-13-2015 10:33 AM
