Can't Catch a Brake.....
Searched this forum but couldn't find a similar problem (or solution). I'll try to keep this brief:
Any help greatly appreciated.
- Initial Problem - When brakes applied during a slow-speed, gradual stop, the pedal would sink down just as the car was almost stopped and the ABS system would engage. No problem when brakes were applied quickly. Decided to upgrade the brake system with new rotors and pads, problem persisted.
- Bench bled and installed new master cylinder; same problem with ABS engaging, only now brakes lock up after 3 or 4 stops.
- Adjusted brake push rod (shorter); same problem, and there is slack before the master cylinder is engaged.by the pedal
- Pressure bled the entire system. ABS still engages when making a gradual stop and brakes still lock up after 3-4 applications, loosen up again sitting overnight. .
