Can't lock my doors -" really need conformation"
Hey hows it going, I have a serious issue wondering if someone can help me - its on my 04 jaguar xtype 3.0 - I just got both driver side door & rear door replace due to a accident - everything went well when I picked it up - car was in great shap fully functional, no issues - but about a week later the fob key alarm won't activate at all - I can't even locked the doors but the strange thing about this goes on & off sometimes it work & not - also I notice when I shut the car off & open the driver side door I get a beeping
(charme) sound, when that happens that's when the fob key dont work at all - really need some conformation
These are the steps that I already tried
•I took it back to the body shop
•I replace the battery on the fob key & car
•I reset the fob key with help from this site
•I reset the car by replacing the battery
•I checked all fuses
•I checked if everything if off
Really need help don't have a garage to put my car in - want to be in the safe side - thanks
jeffmartinaz (05-11-2013)
my 04 does the same things some times. When you pull the key of the ignition out and get the binging, put the key back in a turn it back and forth and take it out again. When I pull my key out and it bings I cant use the key fob lock either but if I jiggle it and turn it back and forth and take it out the binging stops and I can lock the car with the fob. I think it must be the ignition tumbler being slightly worn out and the car thinking the key is still in it.
justin nailed it! It's all about the little metal flap in the ignition. If this flap gets stuck, it still thinks there's a key in the ignition and won't let you lock the car because they don't want you to lock your keys in the car. In fact, I think it is nearly impossible to lock your keys in an xtype due to its locking system.
Holy crap! You guys rock! This was the EXACT issue I was going to post and ask a question about tonight! I bought my '02 (with 72k miles!) a few weeks ago. I've never been able to lock the doors. I didn't get the dinging sound you guys have, but the same issue as described. I just went outside and jiggled my key inside and bingo...they locked! I was ready to take the door panel off to see if something wasn't hooked up correctly. I could open it if I manually locked the door while inside and the key in the ignition. Just couldn't lock it when outside the car. Thanks everyone! One more issue check of my to-do rehab list for this car. Now to decide what to do about the damn oil pan gasket leak. NO WAY IN HELL I'm paying $1000+ for what should be a 30 minute/$35 job I do in my driveway with a normal car!
dont know if this helps but i had the same problem with my passenger door , i did the same as you replaced the passenger door and rear door due to an accident but then the passenger door would int lock done all the things that the site advise but no luck so i took a chance and bought a second hand wiring harness for my passenger door £20 ebay as a last resort (that or jaguar) so i swapped over the harness and bingo job sorted ,so what it boiled down to was that my replacement door had faulty wiring harness hope this helps
Ok problem fix - when I first found this problem I saw a commit from this site that said to put electrical lube inside of the ingintion chamber - I did that nothing happen at the time so I went to other option - but I recently notice this situation would come & go - so I took a further inspection on the Key chamber didn't look right like if something different - so I went to my local car dealer shop they had a xtype there so I checked the key chamber & sure enough the hole where the key goes has a little metal piece that slightly covering the inner chamber that I guess gets caught behind by rubbing & where & tar over the yrs - anyway I used a little electrical lub & played with the lock - mines took awhile had to bang the chamber to release -
It works now I can use the fob key - but will replace the chamber soon ill keep u posted - thanks to everyone that helped out
Good luck.
Thanks. I spent an hour or so online this weekend shooting out emails to some mechanics in the PHX area to get quotes. I've found several as low as $500 parts and labor. I think it helped keep the quotes low by letting them know I'm shopping. I only contacted those who claimed to have experience working with Jags. I could probably spend a couple of days on my back trying to get it done, but I'm afraid I'd screw something up putting it all back together!
99xk8guy
06-05-2023 06:28 AM
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
