cant move shifter
Old 03-20-2012, 08:13 AM
ace911emt's Avatar
Default cant move shifter
2005 x-type
ran perfect
wife washed the car
“it wont start”
pulling back slightly on shifter it will start/ but shifter won’t move
e brake light /abs light and engine light on / electronic parking brake?
gearbox fault on cluster
disconnected battery, 10 min no help
code p1642
fear water in ecm connection from washing
or other connecter?
Old 03-20-2012, 09:23 AM
ace911emt's Avatar
I tricked the car got the interlock to come off and drove it around the block
In limp home mode but when returned home put it back in park the brake light came on and shifter would not move again….. help
Old 03-20-2012, 10:59 AM
ace911emt's Avatar
i had to loose a ground / batt light on then tac drops off every light on in the dash / trans brake system falt has to be a secondary ground for this many problems
Old 03-21-2012, 07:06 AM
ace911emt's Avatar
Default can bus failure
from what i read i think it is a can bus failure, due to water intrusion need help on where it runs and connecter locations /// have others run into this?
n2audio
17
10-09-2015 10:53 PM
Tipptone
10-06-2015 11:32 AM
jjmiah217
09-28-2015 09:09 AM
diablomkii
09-27-2015 07:56 PM
Quick Reply: cant move shifter
