Car not driving well after driveshaft replacement
Old 08-20-2016, 04:35 AM
Lubino Do Rego's Avatar
Default Car not driving well after driveshaft replacement
Hi . I'm looking for some advice on this issue please. I replaced the drivers side driveshaft and lower ball joint however when I put it back together, it felt very different. I felt that the steering wheel was not in the straight ahead position by about 20 degrees or so and it felt a little disconnected from the road. I decided not to drive the car until I could find out what has happened . Any suggestions welcome.
Old 08-20-2016, 02:45 PM
Larry-Cleveland's Avatar
I would go back over your work. Make sure everything looks right and is tight.
If you do not find anything have an alignment shop take a look at it.
Old 08-23-2016, 12:49 AM
Thanks Larry for the advice. I had a look again and it appears that the outer track rod end has failed. The bolt and nut are spinning together. I am going to replace this and then review the situation. The other side will of course need to be done too.
Chuck Schexnayder
02-28-2021 10:27 PM
silversurfer1221
04-06-2016 05:26 PM
Humy
10-08-2013 10:38 AM
chprman
05-01-2008 05:23 PM
10-04-2006 12:42 AM
Quick Reply: Car not driving well after driveshaft replacement
