Car shot at, bullet hit wire, help....
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
Can someone help me, my car was recently shot at as i was driving down a bad block. After i called the police and made a report i noticed that the abs light and engine light is on now. There was a bullet that hit a wire behind the driver fender. I need to find out what is the name of the wire and can i replace it? Help pleasee
Received 6,330 Likes
Received 9,011 Likes
Received 3,912 Likes
dre, let me know where specifically the wire is and what color the wire is that was damaged. I can then give you a better idea of what the wire does.
As for fixing it, I would tell you to find some stuff called "Raychem-070" or "Raychem-050" (050 stuff is slightly smaller in diameter than the 070 stuff, otherwise they are identical). This is shrink wrap on steroids. I use it at work to survive a nuclear reactor meltdown. yes, it is that good. If you can access the wire bundle that was damaged, all you would need to do is to peel back about 6 inches of the wrapping on the bundle in question, slide on a 3" piece of this shrink wrap I mentioned above, join the two ends back together, and then slide this shrink wrap over the wire and shrink it down. The big benefit that this stuff has over normal shrink wrap is that the Raychem has a glue on the inside that after you shrink it down, the glue seals the ends and therefore you will not have any water intrusion into the soldered area (where you joined the two wires). This will make the wire effectively just like knew. If you have multiple wires that were damaged, you can repeat this on each wire.
"In west Philadelphia born and raised
On the playground is where I spent most of my days
Chillin out, maxin, relaxing all cool,
And all shooting some b-ball outside of the school
When a couple of guys who were up to no good
Started making trouble in my neighborhood"
Glad your ok though, That must've been a movie scene in the making.
BrentGardner
28
04-26-2024 03:08 AM
FS[NorthEast]: 1991 xjs v12
DrScientist
12-09-2015 07:36 PM
msdg137
09-16-2015 06:24 AM
Vector
US Lower Atlantic
08-26-2015 05:36 AM
