Car stereo instead of CD changer
Hello,
I have a CD changer in the trunk, but i was wondering if its possible to replace it with aftermarket audio that has AUX input and all the other stuff. Did anyone tried it? what wires/wire adapter do I need for it. I dont think there are CD players with the same sockets as the CD changer.
I want to completely replace CD changer, i know there is smth called AUX-JAG, but like i said, i want to completely replace it/remove it
Received 3,915 Likes
RADas, what you are wanting to do is most easily done by replacing the head unit. The difficulty in this depends on whether you have the NAV system or not. Without the NAV system, it is a piece of cake as the connections are very basic and pretty much, you replace the radio and you are done.
Where things get difficult is when you have NAV. This would mean that you have all the controls for the A/C and heat running through the radio too. To revert back is a lot of work and more cost than it is worth. So, if you have the NAV, replacing the radio is not really an option.
If you look on say E-bay, they do make a kit that will plug into the back of the radio that will give you the AUX input like what you are after. It is like $300 for the kit, but it is plug and play.
RADas-, your best bet would be to look at something like a car PC. Most of the "radio" would mount under a seat and then you would have a small screen that you can find a spot to mount it (say in front of the gear shift). That will then allow you to access all your radio stuff, but then also give you a lot more functionality. Then you would simply use the factory "radio" for nothing more than A/C control and NAV.
The cd changer uses fibre optic cables so I think any substitution is going to be quite involved.
https://www.aliexpress.com/item/1lot...814673932.html
I took the cd changer out and noticed that factory fitted phone in my car is not being recognized now, wondering if this would help to solve the problem
sonicd0012
11-20-2015 11:36 AM
tibam13
02-24-2015 04:11 PM
