Car vibrates when letting of gas..driveshaft ?
Received 2,266 Likes
Spikepaga (07-30-2013)
Received 3,929 Likes
Spike, try applying some grease to the carrier bearing (the bearing supporting the center of the rear drive shaft) and see if your problem changes. If it decreases significantly or goes away, then you have confirmed that your problem is the carrier bearing. If it continues, then you are looking at something else. But, normally with our cars, it is the carrier bearing that is the issue.
What you describe sounds a lot like a U-joint that is starting to go. But, that would be taken care of with the new rear drive shaft.
Spikepaga (08-02-2013)
iawgnix, no, you do not have a rear drive shaft. In your case, this is what I would tell you to do. Start up the car with the hood/bonnet open. Put the car into DRIVE (D) and then with your foot FIRMLY!!!!!! on the brake, give the car a little bit of gas to apply some load. What you are looking for is the motor to make dramatic movement. The motor should move 2 CM or so depending on how hard you are on the gas pedal. If you have a bad motor mount, it will be fairly obvious as you are going to think the motor is coming out of the engine bay.
In your case, pay attention to when you turn, especially when you are accelerating going around a corner. Do you hear this same whir/ticking sound? If so, then odds are you have a bad CV axle. A local mechanic can narrow down which one is bad. If you want to crawl under, normally if you grab on to the axle and try to shake it, one side will wiggle some, the other will be fairly solid. The one that wiggles is your bad one.
On another note, I am wanting to make it back to where you are. I was there back in 2004 and completely enjoyed my time. Stayed at the Charleton Hotel one night there off of the main road near the naval base.
Now I have a horrible clunking noise when I stop the car in drive (tried it in reverse and no sound). I just got under the car and saw the outer cv boot I had redone exploded again, so for sure I have a bad right cv axle and possibly the rear driveshaft Chris mentioned earlier . Car sometimes has a bounce or wobble when I let go and push on the gas again and now clunks and pops at stops. Strangely enough it isn't popping when I turn .
I am not too happy with my X type right now
Me neither. I haven't found a fix for my problems as well. Btw, I just saw another post https://www.jaguarforums.com/forum/x...estion-100366/ looks like we're not alone.
I have taken the drive shaft off. It should take you about 30 to 45 min with the right metric tools. Make sure u spray all the bolts with pb blaster about an hour before working on it. Call me and I can talk you through it if you need to. Also I have what u need my parts car setting on the shelf.
Thanks and good luck,
The Dr!
The Dr!
Thanks Dr. I might take you up on that. The clunking on stops as heard on the video was not coming from the front, apparently. My rear calipers had been grabbing and finally seized, now that brand new calipers are in, the clunking at stops is totally gone . Car still vibrates when letting of gas and then giving gas again, so I am looking the replace that rear drive shaft still.
Thanks!
Thanks!
BrentGardner
28
04-26-2024 03:08 AM
FS[NorthEast]: 1991 xjs v12
DrScientist
12-09-2015 07:36 PM
Sshenton1975
08-30-2015 09:29 AM
Vector
US Lower Atlantic
08-26-2015 05:36 AM
