Cat scratch fever.not by ted
![Arrow](https://www.jaguarforums.com/forum/images/icons/icon2.gif)
![Icon Hyper](https://www.jaguarforums.com/forum/images/smilies/icon_hyper.gif)
![Icon Doh](https://www.jaguarforums.com/forum/images/smilies/icon_doh.gif)
if the paint isnt damaged that bad find a paint-less dent removal place, they do amazing jobs if you find a reputable one. i know of a really good one in mississauga. they have some other locations too. they got a very bad dint out of the jag, it was more of a crease in the door from some lady (used lady loosly...bit**) opened her door extremely hard into the driver door on the jag, then it looked like she pulled back and smashed it a couple more times... it was a crease and a bunch of small dints. they got it 100% out and at a good price, but be prepared to leave your car there for the day. if there are small light scratches they may be able to buff and polish them out.
http://autodentmagicians.ca/
AutoDent MagiciansAutoDent Magicianss
1310 Dundas Street East
Mississauga, ON L4Y 2C1
(416) 434-3368
just checked and they also fix scratches
http://autodentmagicians.ca/what-we-...gblending.html
(416) 434-3368
Received 3,887 Likes
Irish, if you need to call, call. I will pass on what I know.
As for the small dents, see what those paintless dent removal places can do for you.
As for a "scratch repair kit", what I would tell you to do is to find a local paint shop that specializes in automotive paint. Pick up a quart of BRG paint (last time I did this, it was like $20 USD). Also pick up a quart of medium reducer (paint thinner that evaporates over the course of about an hour). From there, you can use a small glas container and put a 3 part paint/1 part reducer mixture in the container and then using a fine paint brush (bigger if the scratch is semi wide-1 mm wide or more) and then fill in the scratch. The big thing will be not to cake the paint on too heavy. Apply a few thin coats vice 1 heavy one. The paint will fill in the depth of the scratch unless there is material that has been removed.
As for scratches in the paint, find a product called "3M Perfect It". It will say either Perfect-It II or Perfect-It III. This stuff will take out a lot of the scratches in the clear coat and works great. I use it all the time to de-fog headlights, remove 4x4 scratches, etc. This can not be picked up at your local auto parts store that I am aware of. When you find the paint store above, they should have it.
dmatthewman
09-30-2015 10:10 AM
