CD Changer not working
Hi DragonKat,
I had a similar problem... whereby my CD changer appeared to just stop working too.
After several hours of checking this and checking that (fuses and connections)
I discovered that the main power supply plug (behind the CD Changer) had been inadvertantly left disconnected.
In my case I had been previously rooting around in the area behind the CD changer to install a reversing sensor module.
Therefore, if like me you've removed the liner in the trunk recently, check the main plug to the CD Changer unit is secure and properly connected.
I felt such a goose when I discovered what the actual problem was.
Hope this helps you to track it down....
philwarner
09-05-2015 10:05 AM
