CD Player
Guest
Posts: n/a
Hi,
I just purchased an 02 X-type and the cd player will not work.
When I purchased the car, the player in the truck did not have the cartridge in it so I purchased one off ebay.
The cratridge installed into unit perfectly and will eject w/no probs but when inside car, I push the cd button and nothing happens at all.
Can anyone advise me to what the problem may be?
Any and all help will be much appriciated.
Thanks, Tammy
Thanks, Tammy
Is your in dash unit a cd or cassette? When you push the CD(cassette model) or CDC(cd model) button does the display try to play the cd or does it just stay on am or fm like you didn't push any button at all? Does the cd changer have the jaguar logo on its sliding door for the magazineor is it an aftermarket unit attached with an fm modulator?
Steve - Check the connections at the CD changer. The head unit communicates, using serial digital commands, with the CD changer via the AINet cable. If the CD does not respond with the appropriate serial digital response, the head unit assumes it is not there and will not respond to you pushing the CD button. This communication occurs at each vehicle start up.
If the AINet cable is not plugged in properly, or connector contacts are corroded (as from moisture in the trunk), or simply the changer is not working properly, the CD option is locked out on the head unit.
Do you have the standard or the Premium audio system? If Premium, also check the AINet connections (two cables) at the amplifier, also in the trunk, mounted above the changer. In Premium systems, the AINet from the head passes through the Amp before going to the changer...
Also, do you have the Navigation system? If so, the AINet signal path goes the the Nav box first (also in the trunk, co-located with the CD changer - it's a DVD player), then to the Amp, then to the Changer... all connections need to be checked. A loose or problematic connection at any of these terminations can cause your symptom; along with a bad AINet connection at the head unit, a bad head unit, a bad Nav, a bad amp or bad changer... hope it's just a loose or dirty connection!
If you have the premium sound and/or navigation, the cable is short, just going from the amp or the nav to the CD.. In this case, I'd suggest getting the proper cable from a wrecking yard.
If you do not have premium sound, the cable goes all the way to the head unit, and it would be a BEAR to replace... I'd suggest trying to fix/jury rig/whatever the existing connector, or replace just the connector or part of the cable from an equivalent short cable from a wrecking yard.
The AINet connector is standard for Alpine systems, so the connector may be available separately from them or their supplier.
I believe I have a standard Jaguar radio. AM/FM/WX /CASSETTE AND PLAYER. I have a multipin round plug in the rear of the radio that has a cable inserted. I believe it terminates in the trunk. I would like to install a player in the trunk, but I am unsure if these plug are universal or specific to a player.
I would also to know where i can find the pin function of the cable
Your info appreiated
07-09-2018 01:44 AM
FS[Western US]: JAguag x350/358 CDC Player Brackets
perezal
12-24-2015 04:20 PM
