cd player changer in boot
Hi: My cd changer suddenly stopped working showing "NO DISKS" on nav window even though there were six in the cartridge. It will eject the cartridge on command from the green button. I removed the entire device (leaving nav screen dvd drive in place) and tried to free up the mechanism and oil the little motors and clean the laser. When put back in the car, the front panel cd button has no effect when pushed. It no longer shows "NO DISKS" of course and now seems to not even know there is a device in the boot. I read through some other postings about codes but those people seemed to have had trouble with the radio itself; mine is fine. Is there a specific procedure for re-coding the original CD changer that came with the car after it has been disconnected and reconnected as is the case here? Thank you. --Tom in Tucson
Your Radio Head Unit should not have 'forgotten' your original CD Changer.
Are there other units (Phone, Nav???) in the fibre optic 'loop'????
Are they in the correct order????
There are electric wires and a BOF (black optic fibre) cable for the communication network.
They need a specific order.
You can test for a 'flash' of the BOF cable to ensure that the head unit is sending an optic signal. I think the signal is sent each time the head unit is power-up. It has been a LOOOOONG time since I did diagnostics on X-Type ICE so I might be forgetting something.
bob gauff
bob gauff
I have swapped changers and no code reset was required. You did good getting the unit apart without busting it. Oh wait, maybe you did bust it!
I opened my unit and fiddled with it, but didn't see anything serviceable by a shade tree guy like myself. You might find something useful in the "CD changer part number" thread.
It's probably just your typo, but the CD button refers to the single disc player in the dash while the CDC button refers to the changer in the trunk.
Sorry I can't answer why your radio can't see the changer now, but the usual fix when it shows No Disks is to eject the magazine and remove the disks from it, then put the empty magazine back in, turn the radio on with the empty magazine in, then you can eject it again and put the disks back in. This worked for me after reading about it on the forums.
Fixed it
Thanks for this. No, the magazine is fine.
In the light of day I took everything to pieces and spotted a hairline crack in the thin ribbon cable connection between the main circuit board and the termination box (which the power and fibre optic cables plug into).
Having fixed this I did a reset as you advised above, which is to put the empty magazine into the system, select 'CD' and wait until the machine cycles from disk 1 to disk 6. Then load the magazine with CDs and play.
Everything now works fine.
Interestingly, my car came with two radio codes. On some other cars I own (not Jags) there is a separate code for the CD autochanger, but not on this X-Type apparently.
I would have tried this had I seen it in time; I already had ordered the used one before the suggestion had been made. But now the 2nd one is failing after a few days. It came with an empty magazine but is older than the one that came out of my car which is a 2001.5 as it is! I will try the empty read for sure.
Five Speed (03-21-2015)
I usually placed the new ones in the owners manual.
Just a thought or explanation.
bob gauff
Finbarr1975
09-16-2023 02:52 PM
Woznaldo
09-26-2015 11:02 AM
