CD Player (single) Won't Eject 2004 X-Type
Thread resurrect- as this was the only one I could find close to the problem I am having.
My single CD player has become intermittent. When you put in a disc, it acts like it does not recognize that a disc has been put in. It goes immediately to the radio, and when you cycle thru AM > FM > CD, it skips over CD like it is empty. And won't play obviously. It will eject fine (usually) and you can put it back in and same thing.
But then later, it will recognize the CD, and play for a while, and then "lose" it and go back to thinking it is empty again. Later still, it will basically act normal and play fine. It might be recognizing it when the CD is in the player when the car is started, but not when the CD is inserted while the car is already running - I need to test that hypothesis.
All this seems to be worse in cold weather - had problems last winter, and has just started happening again now that its cooling off again.
Meanwhile, any ideas? Is there a disc sensor that is dirty or failing or something? Bad connection somewhere? TIA.
Do you have a CDC as well? There are some settings to try. If you're only concerned with the dash single CD, I'd try this first (do the wet one).
https://www.walmart.com/ip/Wet-Dry-CD-DVD-Laser-Lens-Cleaner-Game-Player-Xbox-PS2-Liquid-Included/195849004?wmlspartner=wlpa&selectedSellerId=9760&a did=22222222228163443709&wl0=&wl1=g&wl2=m&wl3=2779 25237886&wl4=pla-464661776628&wl5=9029703&wl6=&wl7=&wl8=&wl9=pla&wl 10=117097115&wl11=online&wl12=195849004&wl13=&veh= sem&gclid=Cj0KCQjwrszdBRDWARIsAEEYhrerh9tdk9p9Mz0M AWpvR1jr_yj8AHKM79seqy7sQtWtOcNuh6mSKAwaAudQEALw_w cB
