CDC not found, not connected or not plugged in properly
Hi everyone,
I have a 2007 X type equipped with Phone (phone and Bluetooth module) + SAT ANV + Audio connectivity Modile ACM+ CDC.
When I press the button on the CDC, it is the radio that lights up and not the CDC, as if it was not recognized.
I went to open it and put CDs but it does not open, maybe not powered ???
I would like to check the connections of the CDC from the trunk to the radio in my dashboard and see if a plug is disconnected or other.
I would be grateful if someone could send me a picture with the CDC connections installed in the trunk and the other connections (dashboard or behind the radio or fuse box). If you have pictures or tracks to explore I'm all for it.
(Other symptoms: (Bluetooth not found + Error message: Phone noit fitted + no sound for SAT NAV).
Thank you for your contributions
On my CD changer in the trunk on my 06 STR the eject button lights up. I’m pretty sure your X type has the same set up. The eject button is a green color when the power is on it. Unfortunately, my CD changer just started giving me a CDC fault message when I push the CDC button on the radio, so looks like I’ll be unbolting that whole set up and if I do, I can take some pictures. I do know all the connections to the CD changer are back behind the unit facing the inner quarter panel bracing so you can’t see it just by looking in the trunk
james5 (02-27-2023)
JustAnotherBob
10-16-2015 06:45 PM
orlee
10-11-2014 01:09 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
