Center Arm Rest - broken hinge 2007 x
Old 04-11-2013, 05:41 PM
Canuck07's Avatar
Default Center Arm Rest - broken hinge 2007 x
The double hinge on my front center arm rest is broken and I am told by Jag dealer that the complete assembly must be replaced. Does anyone know if this is the only way or can you simply buy the hinge !!
Old 04-11-2013, 06:14 PM
GGG is offline
Received 16,858 Likes on 12,186 Posts
You should get better advice on this in the X-Type tech section. Do you want me to move the thread there for you?
Canuck07 (04-11-2013)
Old 04-11-2013, 07:35 PM
Canuck07's Avatar
Yes Graham please do that for me Thanks Gerry
Old 04-12-2013, 05:30 AM
flyrr100's Avatar
Keep checking eBay. Unless you want to pay Jag prices for a new replacement.
Canuck07 (04-12-2013)
Old 04-13-2013, 03:24 AM
GGG is offline
Gerry,
Jaguar carry designs over across the model ranges and the X-Type could be similar to the X300 / X308 / XK8 arm rests. If so, this video may help you dismantle it to get to the hinge. The video is aimed at repairing the cup holder but includes dismantling the arm rest:
The hinge on the other models looks like a standard butt hinge:
If X-Type is the same construction, you've got to be able to get one the right size at a hardware store.
Canuck07 (04-14-2013)
Old 04-14-2013, 11:26 AM
Canuck07's Avatar
Default Hinge
I wish it were a std type hinge but this one has 3 flanges, I'll try and get a photo up. The center consul on the X Type has 2 hinged lids, one on top of the other and one 3 flanged hinge. If I can't locate one I'LL take it apart and cobble up half of a std hinge to fit. Just looking for the easy way out.
Old 04-14-2013, 12:57 PM
Canuck07's Avatar
Default Hinge Photo
https://www.jaguarforums.com/forum/a...1&d=1365961976
Even with the picture it is hard to see - understand
Old 04-14-2013, 05:24 PM
GGG is offline
It looks like the hinge pin is the part arrowed in red and the butt of the hinge has sheared at the point arrowed in blue:
If so, the broken butt has to be a piece of flat plate rolled at the top to take the hinge pin. A machine shop should be able to make a replacement a whole lot cheaper than sourcing even a used arm rest.
Old 04-14-2013, 08:36 PM
Canuck07's Avatar
Default Hinge
That is the conclusion I have come to as well Graham. I will probably do it myself as my background is in sheet metal.
Those arrows you used, do you apply those thru this Jag Web Site or something like Photo Shop?
Gerry
Old 04-15-2013, 05:36 AM
GGG is offline
Gerry,
With your sheet metal background, you may have hit on a market opportunity if these hinges are a regular failure.
The arrows aren't a forum function. For speed, I just take a screen shot then size it and apply the arrows from 'shapes' (circled in red below) in Windows Paint:
For something more complicated with text boxes or call outs, I'd use Photoshop.
Canuck07 (04-15-2013)
Bc xj
09-17-2015 06:34 PM
PinnacleWax
Detailing / Car care
09-16-2015 10:28 AM
MI-FType
09-13-2015 11:26 PM
pocketrocket
09-03-2015 07:44 PM
Quick Reply: Center Arm Rest - broken hinge 2007 x
