Center cap ideas
I still havent been able to find a place that can make me a set of caliper adapters to fit the STR brakes... Well I have but I'm not about to spend $800 on just the adapters which is what was quoted to me by a local machine shop.
Yeah, $800 is a little steep. If you know how to take measurements you can measure everything up and draw it in CAD. From there emachineshop.com it. Get a set made out of resin and test fit them. From there have a set made in 6061 Al or something. The more you have made the cheaper they will be. Get the measurements right and start a group buy. I might be interested in that...
Received 3,904 Likes
chknhwk, if you are still looking for center cap ideas, what size is the opening in the center. If it is 2.25" in diameter, then you can find some interesting Jag caps on E-bay for fairly cheap that would do what you are after. The ones I am thinking of off the top of my head run $12 each roughly (depending on what you can get them for) and they have a raised face. These were normally used on the older XJ series vehicles, but they will fit any rim with the 2.25" center. That way the rims would give more of a factory appearance. You could do a test fit with the caps off of your old factory rims to make sure that everything would work. I am looking at getting a set of the raised face caps for my X-Type as the center caps on my car are starting to fade and I think those would be a nice upgrade.
So yeah, I won't be leading any group buys anytime soon but if someone with the skills/knowledge/patience to pull off a set of STR Brembo adapters wants to do a group buy you'll get your first deposit from me.
#30
Imagine having a garage full of enough carbon fiber aero to make NASA jealous and dealing with the logistical nightmare of transporting/shipping these things... No truck, not even a real trunk (had an AE86 coupe at the time). At least brake adapters would be small/easy to ship. Somebody grab the ***** on this one and let's make it happen!
#31
#32
#34
hen555
09-07-2015 11:13 PM
