central locking ecu location
I have a central locking problem, the keys have been checked and found to be ok.I wonder if it may be the central locking ecu, they are quite cheap on ebay but I dont know where it is fitted on the car and if it needs to be coded.can anyone help
my car is an x type 2.0d 2003
I don't know what you're looking at on Ebay, but the X Type doesn't have a dedicated security module; it's built into the General Electronics Module (GEM) that controls a whole heap of other functions as well. Perhaps if you post the details of your problem, members here will be able to help?
papadigz (05-27-2015)
Check the simple things first.
My 2006 was doing not unlocking itself when you get out, except for the driver door. Similar with the key fob- would open driver, but double-tap for all 4 doors would not work.
Turned out to be a sticky door latch. Spray some silicone lube on it and open/close a few times. Takes 60 seconds, and not a bad thing to do anyway. Try that first no matter what probs you are having, would be my $0.02.
Did you ever find a solution to this problem?
aholbro1
08-05-2021 05:02 AM
