Changed ATF, transfer case and rear differential fluid
2004 3.0 Auto 85xxx miles
This is my first car and I just got my driver license this April. So since I can do this, you can do it too.
ATF--Drain and refill for 4 times
Fluid. Castrol import multi-vehicle ATF from Advance Auto Parts.
Tools. See picture.
![](http://ourlifein.us/pictures/IMG_6278.JPG)
Comparison of 2nd, 3rd, 4th drain fluid, mixture of 2nd and new fluid with the ratio of about 4:1 and new fluid.
![](http://ourlifein.us/pictures/IMG_6284.JPG)
Reverse angle--note the transmittance.
![](http://ourlifein.us/pictures/IMG_6286.JPG)
Another photo--from left to right: 2nd, 3rd and new fluid.
![](http://ourlifein.us/pictures/IMG_6276.JPG)
After 4 drain and fill, looks like the fluid is slightly worse than the mixture of 2nd and new fluid with the ratio of about 4:1. So I guess 70% of ATF gets replaced. You can also do simple math to calculate the percentage of new fluid.
Interesting thing is I get out different amount of ATF. Around 2.5 quarts for 1st, 3rd and 4th drain. 3.25 quarts for 2nd drain.
Transfer case and rear differential
Tools
I tried several tools and combination and here is the best choice for both transfer case and rear differential. One 1/4 ratchet and one 1/4 to 3/8 adapter. As to pumping old fluid out of rear differential, use this pump. It works perfectly. Just insert the pipe below to the drain hole and press the pump. This is what I got. I was wondering what burn smell or stinky smell is. Now I find answer.
![](http://ourlifein.us/pictures/IMG_6291.JPG)
Fluid. Royal purple 75W-140 gear oil for both. It is expensive, 19.99 for one quart bottle from Advance Auto Part before tax. You need 2 bottles.
It is easy to find drain plugs for TC and rear differential once you get under the car. There is plenty of information in this forum regarding how to do the change. Just search and you will be glad to see what you find.
I thought the whining noise at 40 to 50 mph would go away after changing all fluid but I was wrong. Also tried to grease propshaft center bearing with a syringe and needle. No luck. Just can not find right please to insert the needle. I can live with the noise if it is just noise rather than a sign of big problem.
More photos
![](http://ourlifein.us/pictures/IMG_6277.JPG)
Tools. See picture.
Tools
More photos
The following 2 users liked this post by yeeran:
Cadillac (12-05-2011),
lovemycar1 (12-15-2011)
If you see old fluid out of drain hole, congratulations! It is not empty like mine. As I said above, the drain hole is in the middle of TC so you need to drain out of all the fluid before filling if you do not want to drain and refill for several times. Some people lift up right side of the car when drain and lift up left side when fill. I think an alternate is that you use the pump from Amazon (you can also find the same on at AAP) to drain as I did for rear differential. Honestly I did not do this to TC but I think it should work as the mechanism is the same. And when filling you can also use this pump but the most important thing is to find the right fitting.
BTW, just use the 1/4 ratchet (Stanley from Walmart) and 1/4 to 3/8 adapter (from AAP). It takes me a long time to find out the best choice.
Good luck!
Inky7 (12-04-2011)
When I did my transfer case I was pleased that gear oil flowed out and it was somewhat clear..... did it again over the week end and noticed a number in a paint marker on the TC....
Probably was replaced by a previous owner and got a reconditioned/repurposed put in.
Did the diff and the fluid was low and nasty.... flushed it twice now and have my fingers crossed.
good luck and keep doing fluid changes.... lubricants are much cheaper than the parts they lubricate....
![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
innzane
09-02-2015 10:08 AM
