Changed Battery
Hi everyone:
I have a 2006 X Type over the weekend the battery went dead. I checked the voltage output using the onboard diagnostic center. The voltage varied between 14.2 and 13.0. I changed the battery this morning with an after market one. Everything worked great but after about 100 miles I noticed a miss on low end and at idle. Check engine light came on and I pulled the codes P2A01,P2A04,P0101,PO300, along with a misfire on 1,3,4,5 and 6 Any ideas and could the battery cause any of this. Any help would be great
Thanks Scott
Thanks Scott
For those codes
Jaguar X-type P2A01 Engine Trouble Code - Jaguar X-type P2A01 OBD-II Diagnostic Powertrain (P) Trouble Code For Jaguar X-type | EngineTroubleCode.com
Jaguar X-type P2A04 Engine Trouble Code - Jaguar X-type P2A04 OBD-II Diagnostic Powertrain (P) Trouble Code For Jaguar X-type | EngineTroubleCode.com
P0101 Jaguar Mass or Volume Air Flow Circuit Range/Performance Problem OBDII Engine Light Trouble Code | Engine-Codes.com
Jaguar P0300 OBD/DLC Error Code - Random/Multiple Cylinder Misfire Detected
P0101 is voltage related, but that's as much as I know so hopefully the list will help someone else figure them out for you
al_roethlisberger
09-11-2015 10:04 PM
OkieTim
09-08-2015 04:48 PM
