Changed fuel filter and problem started
Hi,
I have decided to change fuel filter(2006 2.0l diesel) after all i did not fill the filter with diesel and i have started the engine. it ran and after couple of second it stalled. It wont start. It is cranking but nothing else. Also i have noticed there is no fuel going to the fuel filter(could it be a fuel pressure??, it has been topped up manually at last), also fuel cut off switch was engaged. F17 fuel pump driver module and relay fuse is ok
After google research and going through workshop manual i have finished on
(310-00)A7: CHECK THE GROUND SUPPLY AT THE FUEL PUMP CONTROLLER
The problem is i cannot locate the fuel pump controller electrical connector CA105
Could anybody help me with this please?
BrentGardner
28
04-26-2024 03:08 AM
X_Type_South_Africa
12-09-2015 05:37 PM
1964Daimler
09-02-2015 11:41 PM
