Changing "Accent Bulbs" in Hi-Beam Enclosure?
Guest
Posts: n/a
This might be the dumb question of the week, but I'm having some trouble with headlights. I've routinely changed my standard and hi-beam headlight bulbs, but I recently had one of the "accent" lights that resides in the high-beam enclosure go out... How the heck do you change that, and what bulb is it? I can get a hold of it (passenger side - the bulb seems to be just up and to the side of the hi-beam bulb), but it just spins and resisted my attempts pop it out.
Any help would be greatly appreciated - I would like to return nighttime incandescent symmetry to my x-type...
I tried changing these bulbs just the other day to LED. Though I decide they look good as is.
ANYWAY, they can be removed by turning it counter clockwise. The bulb is a 194, W5W, T10. All the same just different coding for the bulbs.
Check out http://www.eautoworks.com/ for all the bulb replacements.
Cheers!
Cheers!
If you mean the amber lights on the side you just move the lense forward and the whole thing comes off.
OK, seriously. I too can reach the little parking light connector in the high beam, but it certainly doesn't pull straight out. I must have had 10 lbs of force on it and nothing happened. I also tried twisting the connector it rotates clock wise and counter clock wise, but still the connector is stuck on the head lamp shell.
What's the trick? I'm ready to take the bumper off and remove the lens to get to the stupid thing.
Received 3,884 Likes
cwalker, the trick is just to hold the housing in place (so you do not break the mounts to the headlight) and then pull straight back. If you go at even a slight angle, it will bind up and not want to go. LIke was mentioned above, they are only held in with friction. So, a gentle pull straight back is all that is needed to remove the bulb.
Guy-Pierre Boucher
09-16-2015 05:55 PM
Gerard Radimaker
09-13-2015 10:33 AM
