Changing fuel filter- is it doable by a normal guy?
Received 3,909 Likes
Very simple job. The hardest part of doing this is finding a good jacking point (look just in front of the rear wheels, there is a frame support there or a large jacking plate that you can use). Beyond that, like was mentioned, 1 bolt holding the filter in place and then 2 clips holding the hoses to the filter. Squeeze both clips at the same time and pull the line from the filter. Just be ready to have a little bit of gasoline (petrol) come out of the filter and line.
Also of note, when you go to start your car the next time, odds are it is going to die on your shortly after getting the engine running. This is normal. Turn the key to the RUN position, wait a few seconds and then start the car. This should minimize any problems with keeping the engine running.
MC36
US Lower Atlantic
09-01-2015 07:34 PM
