Cheap approved X-type ATF found!
Hi all,
I enjoy reading all the technical posts and am ready to do full flush on recent X-type purchased. When I searched 'Valvoline Max life ATF' this was one of the results:
VALVOLINE 773775 Transmission Fluid,1 Gal,Red G1769677
I did not see the 773775 in this thread. Question is this correct fluid for 2003 X-type ATF? Also if anyone has recommendation for urethane rear sway bar and link arm bushings that would be much appreciated!
You are well advised not to purchase the Valvoline product unless and until the manufacturer approves its use in your car. Installing the incorrect fluid can cause all kinds of damage to an auto transmission. In extreme cases the wrong fluid can weaken the adhesives holding critical friction linings in place.
Your suspension bushings will respond well to a silicone lubricant, either in spray or tube format.
Jaguar X-Type
Calls for the following fluid specs
Esso LT 71141; Shell ATF 3403 M115; Shell M1375.4; MERCON V XT-5-QM ATF; IDEMITSU K17; Jatco 3100 PL085
This meets and exceeds JATCO's specs;
Castrol Import Multi-Vehicle ATF
Valvoline MaxLife ATF is also approved or recommended for the JAG's JATCO, which is a synthetic based ATF
From another thread, but it relates.
I know folks here use a couple different kinds of fluids, but this is the only fluid I could find that is fully synthetic and specifically included JATCO transmissions on the label.
Red Line Synthetic Oil - Automatic Transmission Fluids - D4 ATF
Used it for a 14 hour endurance race with no issues.
DPK (06-15-2016)
I called Ashland/Valvoline and verified the Valvoline MaxLife 773775 GAL meets Jatco 3100. I found 5 gallon bucket at Jet.com for $89 free shipping. Net cost was $74 after discounts. Part number is different but also verified with Eric @ Valvoline that this is same as 773775.
Valvoline VV349 DEX/MERC Automatic Transmission Fluid 5 Gal
Links to Valvoline compatibility
https://www.google.com/url?sa=t&source=web&rct=j&url=http://www.carquestprofessionals.com/catalogs/chemicals/V-6217%2520ATF%2520Application%2520NON-Laminated%2520Guide%25206.10.13.pdf&ved=0ahUKEwjYs 7_NgqvNAhULT1IKHRi0DccQFgggMAE&usg=AFQjCNEDYz4oIEI MfMaOEmmi4ymNsQZy4w&sig2=jZ9BwJSkCrlaHf_UFRyOgQ
#28
With the automatic transmission being the second-most expensive component on this (or any) car, do you really want cheap fluid? In my experience the best lubricants are made by AMSOIL. You won't find them on the shelf at a big-box parts store, but they're easily obtainable.
I checked the Amsoil.com website and unfortunately they have no products at all for the X-Type.
#30
Using the vehicle look-up on AMSOIL website, you'll see that the ATF specification required is Idemitsu K17. Check the data bulletins for both Multi-Vehicle products (OTFQT and ATFQT) displayed and you'll see both meet that specification. Everyone's got their favorites (fluids, parts); for me it's AMSOIL for the last 20 years.
Jag4 (09-28-2016)
#31
aholbro1
08-05-2021 05:02 AM
al_roethlisberger
09-09-2015 09:14 PM
WTB[NorthEast]: X-Type Sport Wheels
Whitnessmouse
09-04-2015 11:09 AM
