Check Engine light flashing
Received 3,929 Likes
A flashing check engine light is telling you that whatever is going on, is significant enough that the ECU is considering it engine damaging. Now, this can mean that the cats will be damaged, you may crack the block, etc. It all depends on what the car sees as being wrong and to what level it is occurring. LIke was mentioned, get the codes read and have them posted here. Odds are, we can get you taken care of in no time flat.
If I had to take a guess, you most likely have some oil in one of the plug wells and you are having a coil get its spark shunted to ground so the cylinder is not firing properly. This will lead to high gas concentration in the cat and it can cause the cat to run extremely hot. Hot enough to start warping/melting internals.
BrentGardner
28
04-26-2024 03:08 AM
philwarner
12-06-2021 07:13 AM
