Check engine light, P0037
My 2002 X-Type recently lit up the check engine light. I put my OBDII tester on and found the following codes set:
P0037
P1111
The car runs great and there doesn't seem to be any issues other than that little yellow light of doom. Looking for some guidance. I don't find a list of X-Type P-codes but searching it seems like the P0037 is an O2 sensor? What about the P1111?
Any help is greatly appreciated. I'm trying to sell and don't want to pass along a serious problem to the next owner.
P0037
P1111
P1111 means the OBD monitors (google for meaning) have run OK at some point in the past (so it can be ignored).
All codes are in JTIS, a free download. Codes PDF may also be on Gus's site JagRepair.com - Jaguar Repair Information Resource
Okay, got the new sensor installed and reset the code. Check engine went out, all's well. About five miles of travel and the code (P0037) reappeared with the check engine light. Reset again and after about 20 miles it threw the code again. Hmmm. I'm confident that the sensor is correct and correctly installed. Any ideas why this would continue to set this code?
BrentGardner
28
04-26-2024 03:08 AM
