Check engine light and part identification
Luke: The brake booster vacuum line used to be a ~$100 part, but now is ~$20. Consider new instead of used, given the check valve's weakness for degrading with age and heat. The part number is C2S17552
https://www.ebay.com/itm/New-Brake-B...LH_TitleDesc=0
Vacuum retainer bushing
That's definitely the right name for it
the white bushings look like the right shape but they are only 4mm whereas mine needs to be 9mm
The other bosch bushing doesn't look like it's the right shape so im not sure if I should chance that.
Finally that new brake booster line looks very good , ive only one problem tho , my brake booster connects to 3 places , this one only connects to 2 places so I don't know if it will work but I'll show you the spare part I got in the scrap yard
By the way my car is a 07 Jaguar xtype 2litre diesel
Luke: My bad..... I should have guessed from your Ireland location that you have a diesel X-Type.
Suggestion: Click on "User CP" (Control Panel) in the top left of this screen and edit your signature to say "07 Jaguar xtype 2litre diesel" so people know what you drive and can better help you.
For your 2.0L diesel engine, the part # is C2S26896. Search the internet and you'll find those for ~$30 + S&H. Two examples:
https://www.sngbarratt.com/us/#!/Eng...e-d8a72aa7cf23
https://www.terrysjag.com/product/C2S26896.html
https://www.amazon.com/Bapmic-C2S175...words=C2S17552
That first link is perfect for a new brake booster , hopefully it comes with a new vacuum retainer bushing
I'll let ye know how it goes
#28
Luke: If you have a 2.0L turbo diesel X-Type, the parts catalogue has 2 part numbers:
C2S26896 for VIN up to J04730 https://www.sngbarratt.com/us/#!/Eng...e-d8a72aa7cf23
C2S44336 for VIN ending J04731+ https://www.sngbarratt.com/us/#!/Eng...f-9c687f5408a9
SNG Barratt (who sponsors this site) has an on-line parts catalogue with parts diagrams: https://www.sngbarratt.com/us/#!/Eng.../50/all/1/10/1
#30
UPDATE
I've been to all the cart part shops and they can't get the little red bushing that i need, I've been to plumbing shops and pneumatic shops and none of them can get the 9mm bushing.
Ive also been to the main jaguar dealer near me and the don't sell them either and it's not on the vacuum hose /check valve piece so a new one of them right now is no good when I already have a spare.
The Jaguar dealer said the only way i can get that piece is if I replace the whole vacuum pump and that's a big 193 euro for the sake of a little bushing that should cost less that 2 euro.
So at the end of the day i have ordered some guerilla glue and I'm going to connect my quarter broken bushing to the manifold and insert the hose with lots and lots and lots of glue and absolutely destroy the place possibly with the whole bottle just to make sure it all sticks and hope to god that it works.
I'll try keep it a bit tidy looking but the more glue the better I think.
Anyway this glue is meant to be very good in strength and against heat, cold and even waterproof so it should work fine especially if the vacuum force is pulling towards the inlet manifold.
Moral of the story is you push in before you pull out
#31
Or you could try this product. It even comes with a moulding bar to create plastic components.
PLASTEX, PLASTIC REPAIR KITS, FIX CRACKS, REPAIR PLASTIC
BrentGardner
28
04-26-2024 04:08 AM
1964Daimler
08-31-2015 07:41 AM
SingBlueSilver
08-27-2015 03:20 PM
